fuel pump?? (now carb bowl vent mod)
was riding today and noticed my bike starting to cut out at full throttle, get home and my fuel pump is just buzzing and not drawing any fuel from my clear filter......clogged filter or fuel pump on the fritz?? also sometimes it will draw fuel....Im confused
RE: fuel pump??
so my petcock and filter are good, if I turn on the gas and unhook the fuel line coming out of the filter I get solid gas flow, but when the bike is not running and I go to turn it on, the pump just buzzes and vibrates pretty badly....guess that points to the fuel pump unless somebody else has any ideas?
RE: fuel pump??
or a voltage drop across the relay or connection. Winging it here, but a voltage drop to the pump will make it over amp and burn out in short order.
RE: fuel pump??
well here is the thing, it is acting like it is intermittent, if it sits for a long time and I switch it on it acts normal, but after its heated up it just buzzes away, not drawing any fuel through the filter........
RE: fuel pump??
where is the actual fuel pump relay at?
RE: fuel pump??
dang, so much for winging it. hold on, will look it up.
RE: fuel pump??
so besides the fuel pump being wonky, I have issues with this..
http://homepage.ntlworld.com/webzxr/.../ventbowl.html is what it is supposed to look like, here is what I have............... this would explain my cutting out at 80+mph because my carbs and stuff arent equalizing pressure [IMG]local://upfiles/6724/2EFB21540FE141769F9A14CF572915D6.jpg[/IMG] [IMG]local://upfiles/6724/76DA2D86EAFA41DAB2710B0990DEB3A7.jpg[/IMG] [IMG]local://upfiles/6724/692F53BB0235491B9F3A39D5D6217E0E.jpg[/IMG] [IMG]local://upfiles/6724/8B1E43FF281548238D1396FFAC9B8081.jpg[/IMG] [IMG]local://upfiles/6724/8BF85A4103BF49BEA909DD2C55035FE7.jpg[/IMG] |
RE: fuel pump??
hahaq
[IMG]local://upfiles/6724/B90164BCAC2E49AFA6DECDF0D2821490.jpg[/IMG] [IMG]local://upfiles/6724/9972571F6B544BCD9E240721F5A7874F.jpg[/IMG] |
RE: fuel pump??
ORIGINAL: fivepointnine so besides the fuel pump being wonky, I have issues with this.. http://homepage.ntlworld.com/webzxr/.../ventbowl.html is what it is supposed to look like, here is what I have............... this would explain my cutting out at 80+mph because my carbs and stuff arent equalizing pressure [IMG]local://upfiles/6724/2EFB21540FE141769F9A14CF572915D6.jpg[/IMG] [IMG]local://upfiles/6724/76DA2D86EAFA41DAB2710B0990DEB3A7.jpg[/IMG] [IMG]local://upfiles/6724/692F53BB0235491B9F3A39D5D6217E0E.jpg[/IMG] [IMG]local://upfiles/6724/8B1E43FF281548238D1396FFAC9B8081.jpg[/IMG] [IMG]local://upfiles/6724/8BF85A4103BF49BEA909DD2C55035FE7.jpg[/IMG] |
RE: fuel pump??
does this make sense?
