2001 zx7r spark plug?
I'm wanting to know what is a good spark plug for this bike?
cause I dont have a manual thanks |
RE: 2001 zx7r spark plug?
see here on some specs, lists the plugs as well. http://www.kawasaki.com/DefaultFrame...HOWVEHTABS%3d1
dragone "your a saint... your mother teresa... your elvis... your god."
thanks now if only I can find the manual! whats the difference between curb weight and dry weight? and whats it mean when it says: Fuel: Min 91 Research/87 Avg. Oct. Unleaded ??? thanks again! |
yuppers Drag IS the guru..
curb weight is gonna be what the bike weighs underway, with all fluids, and dry is at a standstill, with no fluids at all in it.. no coolant, gas, oil, fork oil, ect.. as far as the gas, i always run top grade stuff.. whatevers available, but keep in mind 93 will degrade to around 89 in just 4 days... they sont tell ya that, but its just part of the evaporative process.. the number of octane is usually an average or the "research" octane and the "motor" octane. thats that "(R+M)" you see on the pump.. but if you ride alot, you can put high test in without fear of degradation to a lesser number.. you'll go thru it before then! it'll be about 160 or so miles to a tank |
