Wire Harness Connector Help
I dissasembled the bike to repair the transmission and the track crash damage. Got a couple left over plugs that are a mystery to me. Bike is 2003 636. No lights or bodywork is installed. Pretty sure I have all the lighting connectors identified.
I have a couple pics. Not great, but they're ok. First pic is off a three wire connector (I believe it isbrown or black)in the same area as the Air Box sensor (the green one). Second pic is a white connector with two wires. It's under the rear of the tank, near the Fuel Pump connector. Any help would be great. Also am looking for a manual on cd for the 03-04. All I have is the one for the 05-06. |
RE: Wire Harness Connector Help
What color is the 3 wire one, and of the two wire one? I too only have the 06 model schematic.
Actually, I just figured out the three wire plug. Turns out it is the (I guess) main throttle position sensor. There are apparently two of them on the right side of the throttle bodies. I had to actually take off the throttle body to even see it. It was apart too long for me to remember everything I had taken off. I got the diagnostic code from the ecu, and it said main tps malfunction. So, that's what led me to take off the throttle body. There is another tps looking thing on the top, so I thought I had it covered when I put it back together...
The two wire plug is Red with Blue tracer, and Blue with Red tracer. According to the 05 06 manual it looks like the rear brake light switch from the rear brake pedal. I don't have the switch on my rearsets since it's a track bike. |
cool, so you are all set then?
Took it for a quick test ride in the parking lot, and it feels pretty good. Can't go far with no lights or tag...[:@]
