using a slipon from a different bike
Old Mar 19, 2006 | 04:18 AM
mr2turbo's Avatar
Default using a slipon from a different bike
does anybody know if a slipon from a different bike will fit a 03 zx6rr? i figure since it's still a side mount, as long as the ID of the tubing is the same and it clears the swing arm...or is there something else that i'm not seeing?
Old Mar 19, 2006 | 04:24 AM
Notstock's Avatar
Default RE: using a slipon from a different bike
Just need to get pc to adjust A/F mix so you do not run lean.
Most cans are tested by the manufacture, of the pipe, and they know what it will do the bike and advise you on additional changes that are needed.
If you use a pipe from a different bike your not sure about the affects it will have on your bike with out going to the manufacture and asking.
Old Mar 19, 2006 | 04:31 AM
mr2turbo's Avatar
ORIGINAL: Notstock
could always just dyno it with exhaust gas analysis....
Old Mar 20, 2006 | 05:29 AM
speedracer138's Avatar
Most Slip-ons flow the same as long as the diameter size of the exhaust pipe and outlet are the same. The high mounts are a little more restrictive. I asked Dynojet for a MAP for my FMF and they told me that most all the Slip-ons are similar. My F4i slip-on dimensions looked identical to the 636 slip-on. So if it fits, use it.
EMS_0525
Aug 24, 2007 02:40 AM
deno
500 LTD
Apr 25, 2007 12:39 PM
kaw98zx6r
May 9, 2006 10:12 PM
mr2turbo
Mar 22, 2006 02:13 PM
klxstiffler
Feb 23, 2006 12:13 AM
