Tailights dont work
Old Mar 16, 2009 | 05:31 AM
luchini06's Avatar
Default Tailights dont work
I have an 06 ZX6r with custom license plate holder and lights. The turn signals are integrated with the taillight. However I had to cut the wiring for the license plate lights to change plates once I got my title from the old owner. So right now I dont have any license plate lights.
When doing this I noticed my tailights dont come on anymore. With the bike on and the brakes depressed the red tailights dont light but the amber turn signals will which are integrated into the taillight still come on.
The only 2 things ive done recently is take the fairings off to charge my battery and cutting the wiring for the license plate lights. I checked and I didnt cut any other wiring besides the ones that went into the 2 LED's for the license plate lights.
Any suggestions on what to check? Not sure if what I did killed the taillights
Old Mar 16, 2009 | 03:54 PM
pfft84's Avatar
did you use any kind of resistor for the LED's?
Old Mar 17, 2009 | 01:59 AM
Isn't the tail lamp and the rear turn signals on different wiring in the harness?
Old Mar 17, 2009 | 02:47 AM
letizia@iastate.edu's Avatar
ya they should be, there are four harnesses i just wired up one on my bike friday. one is break and running light, one is license plate light then you have right and left turn signals
Old Mar 17, 2009 | 06:30 AM
luchini06's Avatar
NOt sure if there are any resistors the LED's were already installed when I bought them but I had to cut the wiring and take them out because you could not take off the nut holding the LED to the plate without cutting it.
So if they are on a different wiring harness then the ones I cut to the plate lights shouldnt effect the tailights right?
Old Mar 17, 2009 | 03:17 PM
pfft84's Avatar
i would say start over, disconnect everything, connect each one at a time, test lights then keep going
CousinLarry
Jul 3, 2012 02:30 AM
Worlok14
Feb 8, 2009 04:12 PM
kawizx7
Feb 12, 2006 06:06 PM
lemac
Jan 8, 2006 11:57 PM
MIPLAYSTATION
Dec 22, 2005 03:01 PM
