Starter Problems
Alright so I just bought an 87 ZX600 and there a few related problems I am currently having. When I try turning it over the starer does not engage the motor all the time. I can hear it working but it is not attaching to the flywheel. I checked the flywheel over and there no teeth missing on it. It does seem to engage after I put it into gear and rock it a few times which is why
i thought it was the flywheel at first. It is also a new starter so you wouldnt think that would be the problem. The weird thing is when it is actually turning the motor over the head light turns on? It doesnt work after the starter starts slipping again. If you have any ideas please let me know. Thanks
In the manual, the headlight circuit and the starting circuit are in the Junction box which is none repairable. You can check out the leads to and from the J-box with your meter to verify. Could be that the J-Box is taking a dump which may explain your headlight question.
