Question!
Old Sep 15, 2008 | 06:06 PM
joeytalks's Avatar
Default Question!
I have an 07' zx6rr does anyone have any suggestions on what kind of sprockets to gt for my bike and is it really worth gettin.....
Old Sep 15, 2008 | 07:34 PM
Not sure, but welcome to the forums. I'm going to delete the double post for ya, I hope that's ok.
Old Sep 15, 2008 | 08:04 PM
mikedrinfla's Avatar
It depends on what you want to do. Do you want to increase excel by changing the teeth count? Not sure what you are really asking? There is no benfit to just changing them out unless they are worn. Please supply more info.
Old Sep 15, 2008 | 08:13 PM
Here is some info for ya.
1. Going down in the front and up in the rear in tooth count will increase excel but decrease top speed.
2. Going up in the front and down in the back in tooth count will increase top speed but decrease excel.
3. Steel sprockets last longer then aluminum sprockets but weigh more.
4. Aluminum sprockets wear faster then steel sprockets but weigh less.
4. The weight difference will not matter unless you are racing competively.
Hope this helps. If you are talking about brands that is the riders preference. Or if you want the best of both worlds you can do what I did and go with a tri-metal sprocket. Aluminum hub and steel teeth. Also if you change the tooth count your speed will be off. So a speedo healer would be a good investment as well.
Old Sep 16, 2008 | 02:53 AM
768 Ryda's Avatar
going down every tooth on the front is like addin 3 to the back just to let u no, most people do the -1 +2 mod and love the acceleration u can get from it and u can still run the stock chain also
Old Sep 16, 2008 | 03:52 AM
wildacex187's Avatar
but wat about the speed? will it be off?
Old Sep 16, 2008 | 12:03 PM
As I posted right before him the speed will definently be off....
Old Sep 16, 2008 | 05:12 PM
oh ok i thought since everybody did that it was because it wouldnt. cool thanx
Old Sep 17, 2008 | 01:07 PM
speedracer138's Avatar
To correct he speed error, you would need to get the Speedo Healer.
Old Sep 17, 2008 | 06:16 PM
ic ic. can one of those gear indicators be installed on our bikes? sorry to thread jack
1stCruiser
Apr 23, 2011 03:27 AM
fastex500
Mar 28, 2008 01:41 AM
BlueDream
Nov 21, 2007 05:35 PM
