Propping up / removing fuel tank on 2005 ZX-6RR
Hi,
I'm doing a coolant flush and change. Following the service manual I need to remove or prop up the fuel tank to get access to the coolant reserve tank. I'm by myself and this will be my first time doing this. I plan on trying to prop it up. I'll remove all the bolts and the drain hose as shown in the manual aside from the bolt under the front seat that allows the tank to be moved up. I assume the fuel line is underneath the tank, I'll keep an eye for it but won't disconnect it. I've seen pictures of ties connected to the frame underneath the rear seat to hold the tank up and will try that. Does this sound about right? I'd appreciate any advice. Thanks! |
