-   Ninja ZX-6R & ZX-6RR (https://www.kawasakiforums.com/forum/ninja-zx-6r-zx-6rr-16/)
-   -   Nitrous on zx6 how much is to much. (https://www.kawasakiforums.com/forum/ninja-zx-6r-zx-6rr-16/nitrous-zx6-how-much-much-30238/)
pboi Sep 16, 2009 01:45 AM
I gotta 94 zx6 and i have a stage 1 jet kit, a muzzy pipe, and a filter. I was going to get the sneaky pete kit, i was thinking a 20 maybe a 50 shot. The motor is stock with low miles, any suggestions?
768 Ryda Sep 17, 2009 07:37 PM
i woud stay around a 20 shot to be on the safe side, also your bike is carb so you will need a wet kit, also wouldnt be a bad idea to go 1 step colder on the plugs and richen up the jets in the carbs so you want be lean when sprayin
pboi Sep 18, 2009 12:33 AM
ya i plan to get wideband to so i can monitor it, hope i dont blow it :eek:
768 Ryda Sep 18, 2009 07:11 PM
wideband is a great tuning device & will save you $$$ at the dyno
pboi Sep 19, 2009 02:31 AM
Now another concern i have is spraying through shifts. On my old gtp i culdnt spray between 1st and 2nd because i could blow my input shaft. Will i see any troubles if i missed shift or if i just kept in on the juice through gears.
