lowering links
Old Jan 17, 2007 | 05:31 PM
biglg7's Avatar
Default lowering links
I recentyl bought some vortex lowering links for my 05 636 i was wondering where once i put on the links i need to measure? so that i know how much to pull the front forks up through the trees
Old Jan 17, 2007 | 07:06 PM
speedracer138's Avatar
Default RE: lowering links
Measure vertically at a point at the rear of the bike (Turn Signal or rear peg) with the weight off andthe bike straight up. Get someone to help you hold the bike up & level. Then install the links and measure again and lower the front as needed. Just remember not to lower the front too much or you will hit the front fender and fairing whenthe suspension compresses. Also, you will lose some ground clearance when cornering.
Old Jan 17, 2007 | 07:24 PM
Ratkiller's Avatar
I'm just curious. Does lowering the front end help with performace handeling of the bike?
Old Jan 18, 2007 | 02:34 AM
shinobi636's Avatar
He ain't foolin'. I had to lower mine two inches for my short a$$. I need to be careful at lower cowl destroyers aka speed bumps, or a steep ingress into parking lots, and driveways. I also had to get my kick stand cut, they didn't cut enough now I need to get it cut again. The bike should lean 30-35 degrees on the stand.
Old Jan 18, 2007 | 03:07 AM
ORIGINAL: Ratkiller
It will quicken the steering and if lowered too much will cause high speed instability.
Old Jan 19, 2007 | 06:30 AM
biglg7's Avatar
ok so i just did it vortex with a inch and a half. So here is the deal i am 230 pounds i rub the liscens plate underneath the bike just in front of the exhaust. also how did you set your suspension stiff?
Old Jan 20, 2007 | 02:49 AM
You have to loosen the top spanner locknut and start tightening the lower spanner nut to preload the shock spring. Don't forget to tighten the locknut when you're done.You may have to preload you forks also. Look in your owners manual; it should show you how to do it.
kdick91
Jun 25, 2014 09:00 PM
motodad
KX65
Apr 16, 2007 09:56 PM
klxstiffler
Jan 7, 2007 12:55 PM
kotacam
Oct 2, 2005 08:56 PM
cyclops
May 23, 2005 07:54 AM
