how do i install this!?
Old Jun 28, 2006 | 07:37 PM
KAWABUNGA's Avatar
Default how do i install this!?
i must be dumb or something because i just got my no-cut sliders in today...there is no instructions!! there is bolts i guess that would screw into the silders themselfs? but the silders are not threaded like the bolts....is there something im not doing right?
Old Jun 28, 2006 | 07:46 PM
frrogger1's Avatar
Default RE: how do i install this!?
what brand did you go with...can you get a pic up
Old Jun 28, 2006 | 08:05 PM
If you got the shogun sliders like i did those bolts replace the stock engine mount bolts be sure to read ur manuel about removing and replacing them.hope this helps ya.
Old Jun 28, 2006 | 10:38 PM
KAWABUNGA's Avatar
i dont know which brand i picked em up ebay...there chrome with zx-6 logo caps at the end
Old Jun 28, 2006 | 10:40 PM
KAWABUNGA's Avatar
correction!!!! i bought them from 58cycle.com
here is the link
http://store.58cycle.com/product_p/b...20636%2005.htm
Old Jun 28, 2006 | 11:38 PM
frrogger1's Avatar
well they look similar to the ones i had on the left side it mounts here
dont mind my bracket being bent i took this pic after a slide....but that is where and how you mount the no cut to the left side....the sliders should have came with some bolts and all you do is replace the stock engine mount bolt with the one that came with the slider
heres another shot with the fairing on
Old Jun 29, 2006 | 12:02 AM
frrogger1's Avatar
if those dont help i will go snap some better ones for you
Old Jun 29, 2006 | 08:31 PM
KAWABUNGA's Avatar
ok i figured out how to mount them i need to take off that stock bolt on the bike....but my i cant do it for some reason...the tool i have is to weak or something.
What did you guys use?
Old Jun 29, 2006 | 09:12 PM
frrogger1's Avatar
what side can you not remove?
Old Jun 29, 2006 | 09:26 PM
KAWABUNGA's Avatar
the right side (the open side)
its the only one i have tried right now because i know when i take the plastic off for the other one its going to be the same..
