Hey guys got a ?
Old Jan 16, 2008 | 12:06 AM
superninja600's Avatar
Default Hey guys got a ?
Its been a while since i've posted, but heres my question.. I had my powercommander hooked up wrong to where it was giveing it 100% throttle or at least telling it was giving 100% all the time but ran fine... i finally tore the bike apart and connected to the right wire and it runs like a bat outta hell now, but from 3,500-4,000 rpms, about my crusing rpms in town it has a terrible miss in it but ubove that and below that runs awesome... think its the plugs or did i muck something up when it was hooked up wrong?
Old Jan 16, 2008 | 01:01 AM
sup_uni's Avatar
Default RE: Hey guys got a ?
first thing to check is the plugs, might have burned them pretty good
Old Jan 16, 2008 | 01:54 AM
Does not sound like you had it custom tuned if the pc3 was hooked up wrong.
Old Jan 16, 2008 | 01:53 PM
768 Ryda's Avatar
ORIGINAL: sup_uni
x2 if u had the pc hooked up wrong this couldv'e happen
Old Jan 16, 2008 | 04:00 PM
speedracer138's Avatar
Your throttle wasn't reset or Zero'd. Best to change the plugs and run some RXP through it. It will decarbonize the combustion chamber & valves due to the rich mixture. However with the miss at that RPM, it seems the Mapping isn't right. You may want to have it custom mapped or try a differnt map.
Old Jan 17, 2008 | 12:35 AM
the bike has two bros exhaust and a k&n filter on it and the map is for that exhaust and filter.. i've erased it out and redownloaded it like 10 times.. but i'll pull the plugs and put in some newbies.. any suggestions on what plugs to run? i've been running a NGK cold plug in my turbo bike but i dont know what would be good for a street everyday bike
Old Jan 17, 2008 | 12:44 AM
Nothing wrong in running the stock plugs.
Old Jan 17, 2008 | 01:46 AM
projectroc's Avatar
ORIGINAL: Dragone#19
Yep, I would put the same plugs you take out, back in . ( not the SAME plugs, but you get the idea )
Old Jan 20, 2008 | 05:53 PM
The stock plugs are what you should use. Did you reset your throttle on the PC?
kwakboy
Apr 15, 2008 01:38 PM
CRAZY
Aug 2, 2007 01:40 PM
ZX12Rider
Aug 2, 2005 03:31 PM
Zx9s4
Jul 25, 2005 03:55 PM
MAD KAW
Jun 18, 2005 09:12 PM
