good alternative to PCIII???
Old Dec 28, 2007 | 04:35 PM
afboundguy's Avatar
Default good alternative to PCIII???
http://store.58cycle.com/product_p/techlusionbox.htm
I was wondering if anyone has ever used one of these and if so how do they compare to the PCIII? I'm looking into saving as much money as possible... thanks...
Old Dec 29, 2007 | 12:05 AM
sup_uni's Avatar
Default RE: good alternative to PCIII???
it should work but think of it like htis
power commander is tested and proven. how much money are you going to save if you end up getting that and it runs the engine to lean and you melt your pistons?
just a helpful hint
Old Dec 29, 2007 | 01:01 AM
768 Ryda's Avatar
ORIGINAL: sup_uni
just a helpful hint
x2 and plus dyno jet has been a item that many people has used and trusted for yrs and i rather spend the extra money just for a piece of mind and no im gettin a good product than rather go cheap and cost u more down the line, cheap is not always good bro
Old Dec 29, 2007 | 02:06 AM
BR0WNIE's Avatar
+1, Just spend the extra $100 on the power commander!!
Old Dec 29, 2007 | 03:38 AM
I do not know much on this product to say it is or is not good. However, having someone that knows how to tune it is also something to be considered. May cost you more to have it tuned compared to the pc3.
Old Dec 29, 2007 | 06:14 AM
speedracer138's Avatar
The PCIII is easiest to tune/ MAP and most Dyno shops are familiar with it. Other better & more expensive alternatives are the BPD controller, The Factory Race Kit ECU or the new Dynojet Wide Band commander.
Old Dec 29, 2007 | 02:43 PM
afboundguy's Avatar
Thanks for all the info... If I'm 'allowed' to spend the money I'll get the PCIII... I was just bored at work looking up parts for my bike and noticed the product... Maybe I'll have to start skimming money from my paycheck [sm=badbadbad.gif]
Old Dec 29, 2007 | 07:41 PM
drunkretard's Avatar
I have one of these in my 07 zx6r. I love it
http://www.dobeckperformance.com/
Old Dec 30, 2007 | 08:29 PM
We put a Race ECU in the 07 Racebike and it works great. The guys on the team said that they burned up PCIII because of exhaust heat on the 05-06 racebike. The Race Kit ECU mounts in the stock location and the fuel map & ignition curves are adjustable independently. The price is comarable to a PCIII & Ignition module combined but you need the programming harness (Too expensive)to adjust it.
Old Dec 30, 2007 | 09:53 PM
sup_uni's Avatar
hey afbound, how did those gauges look to you?
