discomfort from the position of levers
Old Feb 10, 2007 | 11:05 PM
fastex500's Avatar
Default discomfort from the position of levers
Is it possible to adjust your brake and clutch levers to better suit your wrist right? I am6'1 and have a long reach. When I ride my wrists are killing me because when you use the brake or clutch the wrist has to be bent up alot from the weight from your arms on the grips. I figured you could just angle them down a little from the bolt on top but does that make it any better?
Old Feb 10, 2007 | 11:57 PM
gotrice's Avatar
Default RE: discomfort from the position of levers
Yeah, you can adjust them like that. Just loosen the two bolts, move and tighten back up.
Old Feb 11, 2007 | 02:09 AM
Notstock's Avatar
You should not be putting any weight on your bars unless you are turning. If your wrist are hurting than you are leaning and putting weight on the bars and that is not good.
Squeeze the bike with your legs more and use your body to hold your self up, not your arms.
Old Feb 13, 2007 | 12:07 AM
SERGE's Avatar
I'm 6'2". I rotated the levers as low as they can go (carefull with the brake fluid reservoir) and problem solved. Just ake sure the are both about the same for better control.
Old Feb 13, 2007 | 01:20 AM
BigO's Avatar
ORIGINAL: Notstock
You know the difference between black and blue is the grip right?
cwgoff
Sep 2, 2006 03:47 AM
Wannabe250
May 24, 2006 08:50 PM
evor1
Mar 12, 2006 08:22 PM
incabiker
Feb 28, 2006 02:37 AM
Jax 9
Jun 7, 2005 03:32 AM
