Charging System????
Old Jul 11, 2007 | 07:54 AM
speedracer138's Avatar
Default RE: Charging System????
Charging system should be checked above 3,000 RPM and should be around 13 volts or more in normal configuration. Theck you battery terminal connection for contactand tightenss. Clean them with a wire brush and re-install. Spray it with anti corrosion battery post spray.
Old Jul 11, 2007 | 09:23 PM
speedy_rcw's Avatar
I know I am supposed to have between 14.2 and 15.2 when the bike is off idle. I do see a light change, about .2-.3 volts when off idle. I checked the diodes and they seem to be okay. I haven't checked the regulator circuit. I talked to my buddy back in WA who's a Kawi tech and he said it is most likely the rectifier/regulator that is bad. I just wanted to see if anyone has had this problem. I don't want to buy the part and the problem be somewhere else.
Old Jul 11, 2007 | 10:51 PM
liquiddevil2000's Avatar
if your boy's a kawi tech then listen to him...
if not i would bring it to a pro just so u dont keep changing parts that dont need to be changed
and waste money unneededly!
Old Jul 12, 2007 | 03:31 AM
mmi86's Avatar
pull the meter out and test the Reg./rec.
Old Jul 12, 2007 | 07:24 PM
speedy_rcw's Avatar
Checked the diodes with the fluke. But to check the regulator, supposedly you are supposed to use a test light and 3-12 volt batteries, which I don't have just laying around.
Old Jul 13, 2007 | 03:30 AM
PANGUI's Avatar
ok so would doing the dual light mood kill the bat or the regulator on the bike?????and if so how do i fix it. any of it do i replace the regulator or what do i do i dont htink it is the bat becuase i charged it and it turned over fine for a while then the bike jsut died
eyyopomps
Mar 5, 2019 06:32 PM
sylynce
May 11, 2013 03:47 AM
Obonracer
Oct 9, 2009 11:55 PM
Obonracer
Sep 18, 2009 11:02 PM
ZX600E
Feb 6, 2007 02:58 AM
