Chain Removal without breaker?
Anyone know how to remove the chain from an 06 636 without using a chain breaker? I'm really not in the mood to buy yet another tool, and I don't have the money for it, but my chain is look'n nasty and needs some cleaning.
RE: Chain Removal without breaker?
remove the master link and take it off. you know, the chain link that has a open end looking clip on it ??
yup evils right you wouldnt want to use a chain breaker anyway from what i understand they do just that "break" the chain you would only want to use one if you were replacing your chain. also i may be wrong. depending you your chain you will either have a clip type master link or a rivet type master link it will stand out form the rest of the normal links on your chain.
I've always used a grinder, it will save you lots of time and headache. I used the chain breaker once and it broke on me, ever since I've always used a grinder.
The stock chain doesn't have a masterlink. You will have to grind the 2 pins flush with the plate and drive them out with a punch or chain breaker. If you just want to clean it, get a tooth brush, some chain cleaner or simple green, put the bike on a rear stand and get busy. Thats what I do. Brush it like you brush your teeth, then hose it off and spray it with WD40 to remove the water and prevent flash rusting. Dry it with a rag or paper towels and lube it with some good chain lube. I use Motul Cleaner and Lube.
Yeah, I'll probably do speed's idea then. I don't want to break the chain just to clean it and all. I'll just clean it while it's on the bike. Thanks for the info guys.
ORIGINAL: speedracer138 I use Motul Cleaner and Lube. |
