2001 zx6r rear axle nut torque
I need to adjust my chain badly, what is the torque spec for the rear axle nut?? on a 2001 zx6r
RE: 2001 zx6r rear axle nut torque
I believe it is 96 ft lbs for your '01.... You might double check with your local shop or get a manual. :D
Rear axle nut = 92 Ft lbs. Oil drain plug = 21 Ft lbs. Oil filter = 19.5 ft lbs. Chain Slack 35-40mm = 1.378-1.575 inches or approximately 1 3/8"- 1 9/16" total Slack (up and down) as per the 00-02 Kawasaki ZX6R Service manual.
leave it to speed"on the spot" racer. always on top of tech questions. thanks speed we love ya
You're Most welcome. Love you too, but not brokeback style. LOL
i forgot to ask, what size axle nut is that. i need to go buy a socket for it tomorrow. i tryied measuring it and it looks around 32 mm. anyone know what size for sure??
ORIGINAL: speedracer138 You're Most welcome. Love you too, but not brokeback style. LOL |
If you have your stock tool kit, it should have a Axle nut wrench in it that you can use or measure to get the correct size socket.
