03 ZX-6r, Front & Rear wheel BOLT, HEX Sizes????
It looks like I need to buy new tools, Ive got plenty of tools to work on my car but it seems this bike is a whole new ball game.
What are all the specs for removing the front and rear wheel? Front Bolt size? Front Hex size? Front Fork Hex size? Rear Bolt Size? Also, I bought the bike used and some fairing hex are stripped, whats the best way to take them out? Thanks GC |
RE: 03 ZX-6r, Front & Rear wheel BOLT, HEX Sizes????
Ok, there is no bolt on the front wheel, so just the hex size please?
Need to order some new tools ASAP because I need to do some general maintanance on the bike. |
Call the dealer they'll know. I had to cause I didn't have anything big enough. I think off the top of my head the rear hex is 17mm and the front is 24mm
Do you have a dremel? To get the fairing screws out use a dremel with a cut wheel and just cut a line into it. You can use a flathead then to pull it out.
For wheel tools check out Motion Pro for a front wheel hex tool.....T-6 Hex Axle tool. It has 4 sizes on it. 17, 19, 22 and 24mm. I'm pretty sure the front wheel is 24mm. There are also 2 versions of this. A superlight one and a steel one. I'd get the steel one since you can't torque the aluminum (superlight) is only rated up to 90 ft lbs |
You can also save some money and just get a nut and 2 bolts that are the same size. I was going to do that but my dad (car mechanic) bought the 24mm hex socket so I didn't end up doing that...
Check on ebay. I got one that has all 4 sizes for the front axles of most bikes for $20 shipped. Works great.http://cgi.ebay.com/ebaymotors/Motor...QQcmdZViewItem
And another: http://cgi.ebay.com/ebaymotors/600RR...QQcmdZViewItem |
