-   Ninja ZX-6R & ZX-6RR (https://www.kawasakiforums.com/forum/ninja-zx-6r-zx-6rr-16/)
-   -   03 K1 vs 04 M1 (https://www.kawasakiforums.com/forum/ninja-zx-6r-zx-6rr-16/03-k1-vs-04-m1-30263/)
mtank01 Sep 18, 2009 02:45 PM
03 K1 vs 04 M1
Hey,
New to the site, so first of all thanks for reading. I was wondering if anyone knew the difference between the 03 k1 motor and the 04 m1 motor. I tried calling kawasaki directly but they wouldnt give me any details.
I know that the wiring harness is different, but does anyone know the difference mechanically. I have a tube frame car chassis that is based around the 03 k1 motor and would like to be able to have a second motor available. the local junkyard has an M1 at a good price, but I need to know if I can interchange parts, mostly intake and exhaust pieces that have been custom fabricated (are the manifold shapes and locations the same on both blocks), the heads, and the drive sprocket. Most importantly though, are the mounting points for both motors the same. The tube frame is designed around the motor and to use the M1 the mounting points would have to be identical otherwise it would screw up the geometry and statics of the car.
any feedback is helpful feedback. thanks for reading.
matt
95451 Sep 18, 2009 05:25 PM
Welcome To Kawasaki Forums.
Turn On Same Tunes And Enjoy The Ride.
Theirs alot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometime It Takes A Little Longer Then Others. So, hang-in there. Have Some Fun :D
Dragone#19 Sep 18, 2009 11:58 PM
So the zx600 K1 and the 04 M1 is also a zx600? Was looking at my manuals
Welcome to KF
edit: Hit up your fiche and do a cross reference.
mtank01 Sep 21, 2009 02:25 PM
so it is or isnt the same motor?
Dragone#19 Sep 22, 2009 01:41 AM
I still am not sure since I have not taken the time to cross reference. Look in your parts fiche and start jotting down the part numbers. That will assist you learn to answer the question. Good luck
