ZX-11 Overheating
Old Nov 24, 2006 | 10:21 PM
DragonZ's Avatar
Default ZX-11 Overheating
Bike has been overheating. Prior to installing the new thermo, the resovoir bottle was depleting as designed. Now the overflow is coming from the primary as if there is no flow past the the thermo. Could the thermo be improperly installed?
DragonZ
Old Nov 26, 2006 | 07:02 AM
Default RE: ZX-11 Overheating
Double check your stat. I agree.
Old Nov 26, 2006 | 09:50 AM
KevyzToy's Avatar
Check the T stat. If it's ok, make sure the cooling system is bleed properly. Air in the system will cause it to overheat. Just for kicks, check the fuse for the fan. If it's ok, put hook 12 volts directly to the fan to make sure it still works. The only other thing wrong could be a bad fan switch.
jnut
Jun 5, 2007 11:38 PM
DragonZ
Dec 19, 2006 09:11 AM
silverado
Sep 25, 2006 05:59 AM
tbav8or
Jul 29, 2006 04:53 PM
Gerg
Jun 26, 2005 03:41 AM
