mORE pOWER pLZ!
Hello,
What would be the best option for increasing HP drastically on my 2008 650R ninja? |
Well you can always start with the slip on exhaust. I just put a two brothers slip on, on my 09 650 the other day. It is real nice and loud, plus a little increase in hp and torque.
Originally Posted by justin1
(Post 376556)
Hello,
What would be the best option for increasing HP drastically on my 2008 650R ninja? What kind of riding are you doing? You prefer midrange, or you planning on breaking the salt flat record? |
ceramic exhaust bearings, repsol full-synthetic blinker fluid, high horsepower decals, aftermarket flux capacitor, and a go fast wind screen :D :D :D
Hey, even a squid has to start somewhere ;P
I tried painting flames on the side, but it diddent help increase the HP!! I am going to add slip on exhaust and see how that goes. Thanks guys! |
How bout purchasing an ZX6R!
Full exhaust and PClll with custom map give about 3 - 4 bhp. On the road you won't notice the difference. Most of the popular mods - airbox and sub throttle plates - only make it louder or harder to ride.
For any more, you need bigger TBs, port work and new cams. Best option is minor suspension mods and proper set up, then learning to ride it properly. For a drastic improvement, fit a turbo. Rob |
I tried painting flames on the side, but it diddent help increase the HP!! |
as said above set the bike up right learn to ride th $*&t out of it then upgrade to a zx6r
What are you thoughts on:
Two Brothers Juice Box Key benefits include: Features: • Allows addition of fuel required with engine modifications without upsetting stock fuel map. • Integrated buttons provide easy adjustment and fine-tuning of fuel delivery curve without external programming devices. • LED lights indicate fuel delivery settings while tuning. • Won’t interfere with bike’s stock sensors and inputs. • Increases horsepower. • Improves throttle response. • Installs in minutes. • New third generation technology. • No computer needed to adjust your JUICE BOX™. • Plug-in technology (Doesn’t interfere with stock ECU map). • Integrated buttons provide easy adjustment. Your electronically fuel-injected motorcycle/ATV can now boast improved drivability and more power with the Two Brothers Racing “Juice Box™” fuel controller. The Juice Box™ features simple plug and play installation and quick and easy adjustment. No need for computers and complex maps, just use the integrated buttons & LED display. Uses carburetor tuning logic for easy to understand fuel adjustments. If you plan to modify your vehicle then our Juice Box™ is a must. This easy-to-use control unit plugs directly into the OEM wiring harness between the stock ECU and fuel injectors providing precise control of the engine’s fuel management system. |
