Works Performance Shock
Old Jan 7, 2007 | 07:44 AM
calamarichris's Avatar
Default Works Performance Shock
Finally got and installed a Works Performance shock on my 500R. The enclosed instructions su-ucked, but after much experimental mounting/removing/remounting, was able to mount the remote reservoir securely to the rear subframe, just inside the left seat fairing. Tucked away, hidden and secure, but it's mounted slightly cockeyed because it's a tight fit in there.
The shock was $390, but it comes with a tool to adjust the spring preload and it actually permits adjustment without having to remove the shock (like we must do with the stocker.) And of course it has adjustable compression and rebound damping.
Has a gargantuan range of preload adjustment! Much more than the swingarm pivot point will allow.
Haven't had a chance to do any dialing-in, or even take a test ride, but the stroke action is MUCH smoother than stock when simply boinging the rear end by hand.
Will have a ride-report and photos ASAP...
Happy-happy-HAPPY!
Old Jan 9, 2007 | 12:15 AM
mugwump's Avatar
Default RE: Works Performance Shock
Wow, I was operating under the assumption that there was no after market shock available. Sometimes I love it when I'm wrong. My .95 front springs just showed up today, what a match this could be.
Old Jan 9, 2007 | 05:13 AM
ORIGINAL: calamarichris
Happy-happy-HAPPY!
I am not familiar with WP's. Congrats on the shock. You have sag #'s to add to your next ride report?
Old Jan 12, 2007 | 11:45 PM
mugwump's Avatar
I visited their site. Which shock did you get? Are you going to post a review? I hope so.....Thanks for the post.
mandark
Nov 17, 2008 09:09 PM
walight01
Jul 20, 2006 11:40 AM
Marty
Dec 24, 2005 01:52 AM
MAD KAW
Sep 7, 2005 12:41 AM
c10
ZRX1200
Mar 4, 2005 07:39 AM
