Rattley startup
My '07 is super rattley when I start it with the choke on. Is this normal? After the choke is off, it sounds pretty good, but it really sounds rough those first couple of minutes.
Thanks! |
RE: Rattley startup
Sounds like a cam chain tensioner issue. If you still have a warranty, take it to the dealer now.
RE: Rattley startup
First couple of minutes... ?!?!? [sm=noooo.gif]
How long are you letting the bike idle with the choke on? Many people seem to think they're helping their engine by letting it 'warm up' for several minutes with the choke on. This is actually very harmful and will considerably shorten your engine's lifespan. ~Sit on the bike first and prop it straight up-n-down between your legs. (This allows the oil in the cylinder head to spread about uniformly, rather than pooling over to the left when it's on the sidestand.) ~Start it up, using only as much choke as it needed to keep the engine running while you put on your helmet and gloves. ~Then ride gently away, closing the choke as soon as possible and keeping the rpms below 3500 for the first mile. The best way to warm up an engine is to vary the rpm with minimal load. Riding the bike gently and not zinging the engine is the way. Good luck and let us know how it goes. Peace! -CCinC |
RE: Rattley startup
Thanks for the feedback.
I definately don't leave the choke on for any longer than I need to (I've been reading this forum!). Sitting on the bike while first starting may be a good idea though. I usually start it while off the bike. The clackety-ness of the engine lasts as long as the choke is on, whether full or half (which I do after about 20 secs.) and then, when the choke is off, it sounds much better. I'm just wondering if your other bikes sound like this on initial startup (choke on) and maybe it's just a characteristic of this engine or if they purr like kittens and mine has a cold! Thanks again! |
RE: Rattley startup
Every internal combustion engine is a little noisier when cold. The internal metal parts expand as they heat, which means that the clearances between them is wider when the engine is cold. More clearance = loose fitting = noisier, clattery.
But if it suddenly gets quieter when you shut off the choke... that doesn't sound normal. I'd take that to a dealership and let them listen to it. It should be covered by warranty if you bought the bike less than a year ago. Finally, this bike will never be as quiet as an inline-four with shim-under-bucket valves. More moving parts = more noise. BUT the additional moving parts in the 500R's engine allow you to adjust the valves without having to remove the cam, the camchain tensioner, the cam caps, the airbox, the carburetor assembly... There are plusses and minuses to every design. Most riders seem to like louder aftermarket mufflers, because the louder exhaust noise drowns out the engine's natural mechanical noise. I went the other way, by putting sound-absorbing foam on the inside of the fairing and under the gas tank: http://www.calamarichris.com/junk/07...airingdamp.jpghttp://www.calamarichris.com/junk/07...iringdamp1.jpg I don't understand why Kawasaki puts this stuff on bikes with the quieter engines, but not on our clattery 500R. Good luck and let us know how it goes. Peace! -CCinC |
RE: Rattley startup
What makes it more clattery? The 500 that is.
RE: Rattley startup
The stud & nut adjustment type valve rockers on the 500R, and 250R models tend to make a louder clattery sound than shimmed type valve trains. There's nothing to worry about, it's just the nature of the beast.
RE: Rattley startup
It isn't the locknut assembly at the top of each valve that is making the noise exactly.
On our bike, each cam lobe presses down a rocker arm, which presses TWO valves open: http://www.calamarichris.com/ex500/ex5valve-28.jpg See the slotted heads with the pink paint on them to the immediate left of my thumb, above? Notice there is only one cam lobe for two of them. That rocker arm is mounted on a shaft: http://www.calamarichris.com/ex500/ex5valve-25.jpg Those pretty chrome knobs on the side of our engine (to the left and below the camshaft in this photo) are the shafts that the rocker arms are mounted on. On the other hand, here is my '02 ZX9R. On a typical shim-under-bucket design, the cam lobes press the valves directly, with no rocker arm or shaft: http://www.calamarichris.com/zx9r/HPIM0963.jpg It's difficult to see, because it's a small, tight little assembly. The only things between the cam lobe and the valve stem are a cam follower (also called a 'bucket'): http://www.calamarichris.com/zx9r/HPIM0979.jpg And a shim, which come in various sizes to ensure you've got the correct clearance: http://www.calamarichris.com/zx9r/HPIM0985.jpg The ZX9R has fewer moving parts between the cam lobe and the valve itself, which means less noise, lighter weight, higher available rpm and less wear. BUT it's a pain in the @$$ to change those little shims every 6500 miles. Another reason why our bike is slightly noisier than the more modern Ninjas is because we have a primary chain between the motor and transmission. I suspect the reason Kawasaki left this on our bike is to absorb the uneven power pulses associated with our 180-degree firing order. I thought only Harleys did this anymore and was surprised to learn that our bike had one. Because an inline-four engine is perfectly balanced, the motor can be linked directly to the gearbox. Having a primary chain drive absorbs some of those uneven power pulses. Peace! -CCinC |
