| Liquid_pjear |
Mar 24, 2009 06:54 PM |
50 issues
I have a buddies 2001 ex500 that I am trying to get running right. He bought it from some shady "mechanic" and hasn't had it running since. I took it apart last weekend and replaced the plugs, replaced the filters and fluids, and cleaned the carbs. The bike starts up just fine and sits at about 4k choked and about 1200 at idle. It idles just fine but if you try to twist the throttle it bogs at 2k and dies. I find it odd that it will sit at 4k just fine with the choke but then dies when you try to rev it past 2k. If I just crank back on the throttle it will rev just fine but its not smooth, it still tries to bog at 2k and you get a little puff of smoke. The problem is the manual I have for the bike doesn't have a single picture of the fuel/breather line routing so I am curious if they were hooked up wrong originally. I tried to let my buddy assemble everything so he could learn about his bike and he loosened up the throttle cables alot and I am not sure they got tightened back down enough, I am not sure if that could be causing issues or not. Any help or ideas would be great, I have to get this thing up and running this weekend.
