what kinda engine oil do u use??
Old Sep 28, 2007 | 07:42 PM
iORi's Avatar
Default what kinda engine oil do u use??
hi everyone, just picked up an 07 ninja and was wondering what oil u guys use. the previous owner had it serviced at a dealership and they put in 20w50. do any of u run other types of oil besides spec? or is the 20w50 just for break in cuz it has a lower viscocity?? thanks guys
Old Sep 28, 2007 | 08:23 PM
kawasakifan700's Avatar
Default RE: what kinda engine oil do u use??
Im not sure at break in but I use either penzoil or castrol 10w-40. They are cheap but I dont keep em in the motor long enough. If you change it quick you shouldnt have anything to worry about. Just dont run synthetic during break-in.
Old Sep 28, 2007 | 09:46 PM
iORi's Avatar
hm ok. well the thing is i coudln't get it to start cuz the oil light was on. i added more 20w50, but still wouldn't go. i managed to get it started one time, but as soon as i barely let off the choke, it dies again. does anyone know what the problem is?
Old Sep 28, 2007 | 09:48 PM
iORi's Avatar
i forgot to add a little detail. the oil is a little bit above the top line on the guage, but i don't think that's the problem =\
Old Sep 28, 2007 | 09:54 PM
If it wont start it usually doesnt have to do with oil. Id guess it'd be the carbs. A thorough cleaning should do em good
Old Sep 28, 2007 | 10:33 PM
markmeinteil's Avatar
I hope you're checking the oil with the bike up and center. If the bike is on the side stand, then you are over filling it.
Old Sep 28, 2007 | 10:36 PM
iORi's Avatar
yea, i had a friend that held it for me while i looked. would having a little too much oil be the problem though? or should i just take it to the dealership to have everything checked?
ORIGINAL: markmeinteil
Yup, the oil should be at the full line when your holding it straight and halfway up the glass when its on the centerstand.
Old Sep 28, 2007 | 10:37 PM
And, 20w50 is too high of a viscosity. stick with 10w40.
Old Sep 28, 2007 | 10:40 PM
dilysi's Avatar
they don't hold much so its easy to over or under fill them i like to run golden spectro 10w40 full senthict
