Oil Light Turns on when Stopping...
Hello KF,
I was riding my bike today and I noticed that as soon as I slowed down at a stop light that the oil light turned on for a few seconds, then when I took off it turns off...the oil light seemed to go on everytime I came to a hard stop.
Can Someone help me out here?
Thanks!
Thanks!
RE: Oil Light Turns on when Stopping...
It has also happened to me before. (a few times) I suppose the location of the oil sump on the 250's engine must not be in a great location. Making sure that the oil level is close to the top of the sight glass (with the bike on centerstand of course) makes a big difference. Our 250's hold very little oil as it is. The only times I recall the light coming on during hard stops has been when the oil level was just below the sight glass's middle level area.
ORIGINAL: korax123
Do you do a lot of highway traveling? These bikes suck up oil on longer highway rides. Allthough mine hasn't used any oil yet on 55-60mph cruising.
ORIGINAL: Dragone#19
I am curious to know as to why to the oil consumption? Mileage? Factory issue? What is the normal compression test numbers? Although I do not have an EX, an engine is just that, an Engine.
ORIGINAL: korax123
Mostly at high rpms the oil mists and ends up in the bottom of the airbox through the crankcase vent, but...
Its been said that a "factory break in" on a 250 will cause more oil consumption at high rpm because the rings never got a chance to seat at those rpms during break in.
I have had many MC friends recommend this break in, Ive done it on my new Mitsubishi but I buy salvage bikes so I never get to break them in. http://mototuneusa.com/break_in_secrets.htm
My bike was salvaged at 100 miles but the guy that bought it ran the balance of the factory break in, so I wouldnt be a good test subject. For me it varies as to whether I use any oil or not I dont know it doesnt have any rhyme or reason. The Katana uses a little oil too but then it holdsaround 4 qts of oil so a half quart is no biggie.
But running half quart low on a 250 is a death sentence. Going through a half quart topping it off regularly is normal.
Just check the oil regularly and add as needed and the engine will last a very long time.
