Kickstand (Side Stand) Nut on the frame?
In trying to remove the Side Stand (kickstand) bolt on my 2007 Ninja 250. I have found the bolt closest to the front turns but does not back out.
So I was wondering,, Is there an nut internal to the frame at the attachment points for the Side Stand bolts?
If others have a problem with bolt removal of the sidestand attachment bolt, how did you solve / cure / fix the problem of bolt removal? And I would guess the follow on of bolt installation afterwards.
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
