-   Ninja 250R (https://www.kawasakiforums.com/forum/ninja-250r-12/)
-   -   Fairings - 08 on the 07? (https://www.kawasakiforums.com/forum/ninja-250r-12/fairings-08-07-a-22391/)
izel Jun 19, 2008 06:21 PM
is it possible to take the front fairings off a 2008 and put them on the 2007 model? I want to get the front look but wasn't sure if they fit on the 2007? I'm going to think positivitely on this one.
markmeinteil Jun 19, 2008 06:34 PM
RE: Fairings - 08 on the 07?
If it is possible, you would also have to change the headlight, gas tank, lower fairing, etc. Every piece on the '08 has a different shape to it, therefore, if you replace one part, you will have to change the other pieces so they all "fit".
94Ninja250 Jun 19, 2008 07:28 PM
I'm thinking that the mounting brackets will be in completely different locations. If you were even able to attach one / any, it'd look like Frankenstein's monster.
Whapt Jun 19, 2008 11:46 PM
I may be possible with some wok to get everything to fit let alone the price after you buy everything you need may be a little expensive
sombo Jun 22, 2008 08:42 AM
Couple of things to think about with this idea.
First, not a single piece of body work from the '07 was used on the '08. Second, the frame was changed slightly to make it more compact and handle better. Third, the angle of the front forks was changed by 1 degree for better handling. These three things combined would make it either: a)impossible to do, or b)too expensive to bother with since you might spend almost as much as the bike is worth to do it.
Most likely you'll just have to upgrade to the '08 model if you can find one (good luck on that >.>).
dillon Jun 22, 2008 10:10 PM
ORIGINAL: sombo
thats perty much what i was thinking also...
Dbovey64 Aug 24, 2025 06:07 AM
It has been done
https://cimg3.ibsrv.net/gimg/www.kaw...482850e45a.png
On Facebook market place someone put 2008 fairings onto a 2007 ninja 250r
https://cimg4.ibsrv.net/gimg/www.kaw...994af4ac48.png
https://cimg5.ibsrv.net/gimg/www.kaw...65d8f34888.png
https://cimg6.ibsrv.net/gimg/www.kaw...f377789296.png
