Bike back up, two problems though
So i took her out for a born-again virgin ride and everything was going good, first little thing i noticed though was the airbox is hitting the top of the rear shock, not sure if missed some small bolts or what, not sure where to pin-point that problem either, but the second is i've noticed a squeeking noise when i go over bumps or little inclines on the road, but i can't pinpoint that either, i sounds like its coming from the rear shock or the swingarm axle.... maybe rear wheel axle? i dunno, anyways its annoying and makes it sound broken, like a loose pulley on a car almost, i'm gunna try to get out later and put her on the center stand, see if i can't find the problem, but any suggestions?
quick pics i took in the link http://s201.photobucket.com/albums/aa3/MottPower/ |
RE: Bike back up, two problems though
looks good, I like it the street fighter look.
Turned out nicely I must say. What size rear tire do you have on it?
Dont know without seeing it, but Im betting if you fix the bumping the airbox you can fix the noise. do you have a stock shock?
Go to www.ronayers.com and look at their parts microfische to see what your missing. |
got it! seems as though it was the fuel tank, one of those rubber bushings fell off at some point and i guess i didn't notice, put some duct tape around it real thick and everything is good! i thought for sure the rear shock was hitting because i felt a nice jolt sometimes but i went out tonight and felt nothig after the duct tape fix.... weird
mark, i'm using 90's on the front and rear, seems to dip into corners much easier, i haven't been able to take her to the edge much but i'd like to find a nice road which i can, nice tires for how much i got them, nice and sticky |
