please help
i am trying to go out side the box with a 1986 Kawasaki bayou 185. I managed to short out the cdi box and cant afford a new one :( and then some how trying to rewire in a ford ignition module i fried the coil pack :mad: so now i am trying to wire the quad with the ford ignition module and an accell super coil i can get spark out of it when i try to start but after that there is no spark and the pulse generator isn't wired into the diagram i have so here is the question any one out there have any luck with this type of situation
Originally Posted by drgnsbld
(Post 458533)
wow! So much for your learning curve. Things are adding up for sure. Get the right tool for the job and be done with it. Welcome to KF
the question i have is has any one came across the same problem cause i cant afford a new cdi box they are like a couple hundred dollars
and is there any tips and tricks anyone knows about that might help
Welcome to the forums! :)
Nah I never tried usin diff coils and cdi boxes to make it work. You probably could find someone that has. Im no electrician by any means. I know barely enough to get me by haha
I am unable to help you out on your question either but as I tried to mention earlier, it is normally cheaper in the long run to just get the recommended part and not try to re-invent the wheel so to speak.
