Clutch
My son's 2005 KX65 clutch checked out. I replaced and did the following:
Filed grooves from basket ears. Replaced 5 fiber disks and 4 steels Replaced the springs Replaced the complete hub Replaced the actuator Replaced push pin with one shim Replaced the cable Thrush washers are in correct position, per manual. Fibers were pre-oiled and using Honda Red oil 10/40 Cable adjusted with 2-3 mm of free play Clutch is still not working. Any ideas? |
