dang and blast dat clutch!!!
Old Nov 21, 2007 | 02:54 PM
ilyamomorte's Avatar
Default dang and blast dat clutch!!!
has anyone tried fitting a clutch from a l8r year kx250 to a h2 1991? is there a difference in the shaft between 1991/1992? having problems getting hold of clutch basket and hub, its a b*tch. cheers an beers all round!
Old Nov 21, 2007 | 10:22 PM
OMalley912's Avatar
Default RE: dang and blast dat clutch!!!
I hear ya, Had a 92 kx250 and the basket was really notched up. I just took a dremel and filed them down a bit. I think they are the same but not 100%. Was going to buy a Hinson but way too much cash.
Old Nov 21, 2007 | 10:24 PM
OMalley912's Avatar
Oh and definatley use an impact wrench that nut on the hub will get loose after riding...probably know that already.
Old Nov 22, 2007 | 05:33 PM
thats the problem, the basket has hit the dust with two broken teeth and i was hoping for an alternative to the open wallet surgery that is required for a billet jobbie. must be a mobike mechanic somwhere who can give me advice on this. might try kawasaki directly but wont be holding my breath. happy riding everone and remember, you only die once so make it a good'un!
Old Nov 23, 2007 | 03:29 AM
OMalley912's Avatar
I busted off one of the4 screw posts off on the basket because like and idiot I stuck a scew driver between that andteeth to get the main nut loose.duh!...see previous post. Anyway I took the basket to a radiator shop and he welded it back on. Cost only 25 bucks! Was good as new. Maybe try get a welded and see if it stays and if it don't , there's good ole' ebay.
Old Nov 23, 2007 | 08:25 PM
kewl, i was pondering gettn sum aluminium wire for my mig welder and trying that but didn no if it wood work, iv never welded aluminium b4.i jus got this bike, bot if off ebay wit the seller saying it jus nneded piston an a barrel re-plate. it duz but he never mentioned dodgy clutch. still, on the good side it did av a new ohlins shocker fitted (complete wit ohlins sub-frame)a month before i bot it and everyfn else seems to be in good nik, well worth 400 kwid. fink i'l go for a re-sleave wen iv got clutch sorted. cheers amigo!
Old Nov 24, 2007 | 05:30 AM
OMalley912's Avatar
Sounds good, let me know how it works out. I see your from Scotland, that's got to be some sweet riding. My brother was in Edinborough for a week and showed some amazing photos. Being half Scotish and half Irish I'd like to get there one day, maybe ship the bike over and just travel around. But until I come into a bunch of money I'll be here! Cheeers!
dan888
Nov 20, 2010 02:05 AM
CousinLarry
Oct 9, 2009 02:04 AM
dan888
Nov 14, 2008 12:29 AM
whitehendrix
Oct 18, 2008 02:39 PM
deej
May 31, 2006 07:29 AM
