Newbie needs help!
Old Mar 21, 2007 | 07:57 PM
KxAdam's Avatar
Default Newbie needs help!
Alright guys 'n gals ) I've just become the proud owner of a 1989 KX125.. with a shredded gearbox!
Every gear is okay, apart from the main shaft which has a cog actually machined onto it. Two teeth are missing from it, as are two teeth from the opposite gear. I've seen a few bikes bein broken on eBay, but they're different model years. I wanna know if the gears will go straight into my bike?
Any idea's peeps? Can give my frame # if that helps cheers in advance :-)
Adam
Old Mar 22, 2007 | 05:18 PM
Default RE: Newbie needs help!
i don't know. but welcome to KF
Old Mar 22, 2007 | 06:08 PM
I don't know either, and also welcome. Sorry........[>:]
Old Mar 29, 2007 | 03:18 AM
Lyn125's Avatar
ello,
i have a 1989 kx125 too!!!
wish i could help you out, but i never had to deal with my gear box (knock on wood)
if you find out a solution, please pot, cause im curious, and if you dont and are looking to part out, You got a buyer.
good luck!
Old Aug 5, 2007 | 05:43 AM
gouchie20's Avatar
Go to /www.babbittsonline.com and out in your bike. Go to tranny and look at the diagram. Copy down the part numbers you need. Start over and change info to that year bike and check. And if you have to go to the dealer you have the part #'s.
kx125 88 owner
Old Aug 6, 2007 | 05:36 AM
Welcome to the forums!
Find a fiche as said above.
74 CR 125
Apr 9, 2013 01:32 PM
jvpetruzzelli
Mar 12, 2009 02:43 AM
jvpetruzzelli
Mar 10, 2009 04:09 AM
SavageKen
Apr 25, 2007 01:23 AM
Snal
Mar 4, 2007 08:53 AM
