need help on inch torque power for my 1989 kx 125 clutch
Old Sep 16, 2007 | 02:06 AM
disasterouskid14's Avatar
Default need help on inch torque power for my 1989 kx 125 clutch
I just bought a 1989 KX 125 and the clutch was broken, so i fixed it but the peice that goes over the 5 springs in the clutch, that releases the clutch, needs put on, but the guy I took it to said I had to figure out how much inch torque power it needed so he could put it on and i dont want to pay 15-20 bucks for a new book, because i didnt get one with the bike
if anyone can help thanks a lot!
Old Sep 16, 2007 | 03:08 AM
mmi86's Avatar
Default RE: need help on inch torque power for my 1989 kx 125 clutch
what bolts the clutch pressure plate? or the clutch cover?
Old Sep 16, 2007 | 03:10 AM
mmi86's Avatar
if its a the pressure plate just snug them down evenly, i know most are6-8ftlbs, just do 84inlbs if you really think you must
Old Sep 19, 2007 | 04:43 AM
yea recently i just found out, that it was the spring holder, that i had, but the guy i took it to said it still needed to be inch torqued, but someone else told me that i just needed to criss-cross tighten them?
Old Jul 20, 2009 | 03:02 AM
kxproblems's Avatar
i have kawasaki kx125 but i have problems about its cylinders oil(4t) the 4t turn white when i change 4t... it is normal?
hoedogg
Mar 8, 2008 05:50 AM
atrimbleracer
KX125
Feb 26, 2008 05:43 PM
atrimbleracer
Feb 25, 2008 04:32 PM
c10
Aug 9, 2006 02:50 AM
