Suspension Linkage Bolts
Old Dec 29, 2022 | 11:52 PM
just john 524's Avatar
Default Suspension Linkage Bolts
I am installing lowering links on my 2022 KLX300R and discovered that the new linkage is slightly thicker and the collar (flat surface area) of the bolt is about 12mm too short. Has anyone encountered this issue and if so what is the fix? Does anyone know if a suitable bolt might be readily available? I was thinking that the KXF hardware might be a bit thicker and therefore the bolt might be an applicable substitute. Perhaps I could take the OEM to a shop and eyeball other hardware. Any information will be greatly appreciated.
Old Dec 30, 2022 | 03:05 PM
tooter's Avatar
What brand of links did you get?
Old Dec 30, 2022 | 06:37 PM
Default Lowering Linkage
NICECNC. Off of the Amazon site. I guess I
should have known better. They are a really nice looking product.
Old Dec 30, 2022 | 08:12 PM
tooter's Avatar
Kouba links use the stock bushings and are recessed to fit the stock bolts. They offer three sizes for 2020 and newer klx300's.
KLX3 1.25 Inch
KLX4 1.75 Inch
KLX5 2.25 Inch
They fit perfectly.
ldkr
Apr 27, 2021 10:42 PM
jdbird613
May 14, 2020 10:43 AM
Nikolaj Lykke
Jun 19, 2013 08:51 PM
durielk
Aug 8, 2011 05:31 AM
Daves_636
Aug 31, 2007 11:54 PM
