Front sprocket
Old Aug 23, 2020 | 04:53 AM
Rocky Hernandez's Avatar
Default Front sprocket
I also need your help on how many ft-lb did you do on your front sprocket someone else said 52 what did you do.
I own a 2020 KLX300R. Hope you can help. Thanks
Old Aug 23, 2020 | 01:57 PM
Where's the mud?
You can find a manual online if you look, freebie. If you have a new 2020 300 you should be able to find it in your owner's manual.
I understand one manual says 80 ft-lb, D. Pippin has a torque list in his site copied from a Kawasaki manual, KLX250 I would expect, showing 94 ft-lb. Others have commented seeing other model specs of 69 to 75 ft-lb. Key point, would be that the lock washer with the folding tab should keep it in place at any of the specs noted. I'd tend to lean toward the 75-80 ft-lb and use a bit of anti-seize compound on the threads. Torquing to 75-80 ft-lb with anti-seize may give a dry thread torque close to that 94 ft-lb, but I don't know that for sure. The benefit of the anti-seize is when you need to remove the nut. It won't be crusted on in place.
Old Aug 23, 2020 | 04:45 PM
Originally Posted by klx678
Where's the mud?
will I went with 52 ft-lb and i crush the washer
Thank you for the info 🇺🇲🤙🏼
snappster
Nov 11, 2017 05:47 PM
ortme
Oct 4, 2013 07:50 PM
75vette
KX125
Oct 28, 2008 09:47 PM
andso77
Sep 5, 2007 12:58 PM
blacktail
May 8, 2007 04:56 PM
