97 KLX300 with a blown motor. WHere can i get a new or used engine?
Old Jun 1, 2008 | 01:03 PM
Bonicchevy's Avatar
Default 97 KLX300 with a blown motor. WHere can i get a new or used engine?
will any other engines fit in a 97 klx300? Will a 2007 klx250 engine fit in it? where can i find parts cheap?
Old Jun 1, 2008 | 10:21 PM
2k1w=no$'s Avatar
Default RE: 97 KLX300 with a blown motor. WHere can i get a new or used engine?
The older klx250r 94-96 will fit in the klx300. You will go down to 250cc though and I belive to take that motor to 300cc and above the cases will have to be enlarged to fit the 300 jug.
All years 300 motors will fit.
The klx250s motor will fit. You may have to change over some things for this engine to function properly. I know for a fact that the shift star has a different position for the neutral light. The cdi box uses DC current instead of AC like the 300(it may be the other way around) To use the starter you will need some other items that the 300 doesn't have, and that brings us to the point that the 250s doesn't have a factory kick starter. You may also need different air box boots.
What happened to the motor in your 300?
marc11
18
Oct 8, 2013 08:17 PM
stez71
May 24, 2010 03:30 AM
wakrein
Feb 6, 2010 02:55 PM
grip
Jun 2, 2008 11:56 PM
bigfoot9088
KX125
Sep 7, 2007 04:11 AM
