valve clearance check.
Old Mar 22, 2006 | 08:49 AM
Ginsu4u's Avatar
Default valve clearance check.
We have only 5-6 hours on a klx 125l and it backfires when you de-cellerate in first or second, rarely in third. It is also hard to get it to idle when cold. Someone suggested to check the valve clearance but I am hesatent to do this myself. I have seen postings about other bikes and valves just not this one. If anyone has pics of their valve work please post them. I would like to do it myself since it is a new bike and I have more than one. Is it difficult? Any special tools I may need? Thanks in advance.
Ryan
Old Mar 23, 2006 | 05:26 PM
Ginsu4u's Avatar
Default RE: valve clearance check.
So I ordered the shop manual for the KLX125 a/b but it is back ordered. Guess bike will sit until I get it.
Old Aug 30, 2006 | 04:33 AM
Cowboy 6's Avatar
I would take it to the dealer. You should not have any valve clearance change in 5-6 hours of operation.
Old Aug 30, 2006 | 08:00 AM
BigRig18Wheeler's Avatar
I can't give you much help on that bike on the valves.
But, have you checked the air fuel screws to make sure they are the right turns out? In?
Old Sep 10, 2006 | 04:33 AM
Ginsu4u's Avatar
Valves were ok. It was the fuel screw. 1/4 from the factory. I'm at 2 now. Runs fine now and MUCH easier to start.
Thanks.
Ryan.
p.s. Much easier to work on than the 250s. Lots of clearance. That part was nice.
Old Sep 10, 2006 | 04:36 AM
Notstock's Avatar
Another good call by BR, endless knowlege
Glad you got it figured out Ginsu, What altitude are you at?
Old Sep 10, 2006 | 06:13 AM
Ginsu4u's Avatar
2000 ft. I read somewhere that the fuel screw should be at 2.5 turns and an adjustable needle should be added. I chose 2 turns and it seems to do the trick. I didn't modify the exhaust as suggested by some other forum I read (Thumper Talk??). I will add an aftermarket exhaust this winter.
Old Sep 10, 2006 | 09:49 AM
ORIGINAL: Notstock
All right man, here's your $20 bucks....lol lol
Glad you got it fixed....It's always easier to start at the easy things.
Malves
Mar 23, 2013 09:33 PM
teddybear
Jan 28, 2009 07:27 AM
chris72a
Apr 5, 2008 01:39 AM
Sturgell
Nov 15, 2007 04:27 PM
stunner388
Oct 10, 2007 02:05 PM
