Zeta quick throttle tube
How Many people have installed the zeta quick throttle aluminum tube or something similar (what kind) and how do they perform.
I got the Zeta since it was the only one I found at the time. Grease the bar over the area where the tube will be so it will not bind up if dry.
It allows me to hit full throttle easier/quicker than the stock one. Obviously done by a bigger radius cable pulley. Set for both cables and not too hard to install after deadjusting the cables for max play at the carb. I forget, I may have put it on when doing jetting, so the cables may have been detached. I want to get a quick pull for the 650 too. No more re-gripping to get full throttle. |
You got a link to it? I was going to just get the whole Magura 314 throttle and replace the stock assembly. Wire up a momentary on kill button to use as my starter button. My throttle housing doesn't tighten enough on my bars anyway.
http://pages.ebay.com/link/?nav=item...d=231194771178 |
I prefer a really quick throttle. It's not quite as quick as the 2 stroke assembly I put on my 07, but it's quicker than stock. I'd by another.
Originally Posted by Werloc
(Post 522537)
http://pages.ebay.com/link/?nav=item...d=231194771178 Contact Wheeling Cycle Supply to make sure you get the right part. I think the one for the Dtracker works for the S. I think their listing on their site is for the Japanese market since we never had the DTracker in the U.S. and certainly no 2004-2005 KLX250s. |
Cool, I'll look into it. Thanks.
Yes, I prefer a "Very" quick throttle as well. Does anyone know what's different, if anything, between the Magura 314, and the 314 DUO...? |
Originally Posted by zomby woof
(Post 522544)
Since I'm getting different switches, I'd like to see what all my options are. Thanks....:) |
I have the Zeta quick throttle tube now, but used the Motion Pro Vortex on my 07. It's just a standard 2 stroke (single cable) 1/4 turn throttle. It was faster than 1/4 turn n my KLX and I loved it.
(Post 522561)
zombie and klx, Thanks guys.
