WOW!....NOT!
As I was looking at this newslip-on offeredby Yoshimura, I was thinking there might be some interest in it stateside. After looking at theprice (over $600.00), however, I doubt there would be much of a draw.
If you want a larger head pipe to go with it, that's another $200.00! Sheesh! first they copy Akrapovic, then they jack-up the price becauseit carries the 'Yoshimura' label.
you can build your own......and after you master that ,you can build some for your buddies and sell them.
Pipe bender....89.95 from harbor freight.
tubing....50$
screw ups?? only 3 allowed.
oh yeah...you need a welder.
tubing....50$
Sorry to tell you the harbor frieght bender is for pipe not tubing. It'll pinch the tubing, what you'll have to do is buy the tubing in different bends and cut to fit.
you need the bender with the rollers not the dies.........The dies will pinch the tubing the rollers will not....HF has the junk......I got mine elsewhere but they have a similar model.
next time you wanna bend hollow tube, fill it with sand and cap the ends. This will keep it from pinching and or splitting
