Wire underneath front sprocket?
There is a wire that plugs in underneath the sprocket. Is this a temp sensor or something? Mine is barely hanging on there as the shifter seems to help guide branches into that general area.
Thanks,
Chris
Thanks,
Chris
That is the neutral indicator and safety switch. FYI : I if you pull it off your bike will not turn over. If you pull it off after your bike is running it will keep running.
gsound70
800, 800 Classic & 800 Drifter
Jun 26, 2009 02:05 PM
