-   -   Why do many change handlebars? (https://www.kawasakiforums.com/forum/klx-250s-71/why-do-many-change-handlebars-37864/)
Stashu Apr 30, 2012 12:46 PM
This is a curiousity question.
Why do many change their stock handlebars? I mean the ones on my 2012 and 2006 KLX 250s seemed to be fine.
Is it because it's steel or aluminum? Stock bars are painted? Angle, height? Brand name?
Again just curious
Thanks!
Stashu
EMS_0525 Apr 30, 2012 12:56 PM
i change mine cause i bend them. Im on my 4 or 5 set....
cegusman Apr 30, 2012 01:03 PM
They are weak. Mine bent after 3 light falls. Friends bent after one. Also I need the bar height raised so the bike would fit me better.
stephenmarklay Apr 30, 2012 01:27 PM
Aside from apparent weakness as some have found, riders even on this forum range from like 5'5" to 6'4" and handlebars are the easiest way to adjust the cockpit.
Stashu Apr 30, 2012 01:36 PM
Thanks
Do you find Seel or Alumin better for you "stronger" ??
Stashu
EMS_0525 Apr 30, 2012 01:40 PM
Thick walled aluminum. I have renthals on now.
MaverickAus Apr 30, 2012 02:04 PM
They bend easy and aftermarket bars are easier to mount BarkBusters™
lonnie_vining Apr 30, 2012 02:13 PM
Im thinking about installing FLEXX bars. Anyone done this?
deej Apr 30, 2012 02:42 PM
ohhhhhhhhhhh you guys are bending them when you drop the bike....well that's where you veered.:p:p:p insert if you aren't wrecking then you aren't riding fast enough....:rolleyes::rolleyes::rolleyes:
BillMoore Apr 30, 2012 03:24 PM
Yup, bent mine up pretty badly, so upgraded to something stronger. The lighter weight and better seating position were bonuses...
