where can I order the front sprocket?
Old Mar 21, 2006 | 05:05 AM
motoguy128's Avatar
Default RE: where can I order the front sprocket?
Not to jump off subject, but how much power does this bike have for acessories. Have you broken down the pwoer consumption? I'm never sure how much the ignition uses. Does it have a peak rating for the amps it draws at redline (highest consumption). I'd love ot some day add a power outlet to charge a vest and gloves or even a cell phone or GPS. If they ever make a aftermarket seat I'd still like to consider doing some adventure touring on this bike. You can hit some really knarly tight trails that the KLR or a BMW can only dream about. Just add a small flyscreen (clipped to the bar) and it should be descent for longer distances. Am I insane? Maybe they'll update the KLR and I'll just buy that.
Old Mar 21, 2006 | 07:12 AM
bmwhd's Avatar
ORIGINAL: motoguy128
The charging system makes 2A less than a KLR650. Let's assume that power consumption is about equal between these two bikes since they share the same headlight, turn signals, etc.
The KLR650 is well known to have between 70W and 80W spare juice at speed. So our bikes likely only have 50W or so to spare.
I've been using my 77W Gerbing jacket liner set on half power with no problem which makes sense given the above. I've got the LED tail light which saves 4W nominal and 20W with the brakes applied. I plan to swap out the headlight for an HID system which will save me 20W more.
USMCsilver
Apr 27, 2011 08:07 PM
kpwestmo
Aug 4, 2009 01:23 AM
MK1gti20v
Aug 12, 2005 04:49 PM
spirithawk
Jun 4, 2005 03:24 AM
