-   -   Vacuum port question (https://www.kawasakiforums.com/forum/klx-250s-71/vacuum-port-question-33613/)
sanpedro Sep 8, 2010 08:10 PM
Hi, there, another noob-ish question. I just pulled the evap system from my '09 Cal. model. Between the carb and cylinder there is a vacuum port, like a t with one fitting each for the evap and air injection systems. I plugged both of the little hose fittings with rubber cap plugs, but I'd rather remove the whole thing (the T). Catch is, I can't find a diagram of it, so I don't know if its threaded in or pressed in and I'd rather not break it trying to find out. Has anyone done this? Thanks.
