Turn signals/rear fender?
Old Feb 25, 2006 | 07:52 PM
tennisman's Avatar
Default Turn signals/rear fender?
Hey, I just bought a new KLX 250s and of course want to "clean up" the looks a bit. How difficult is it replace the goofy turn signals with flush ones? If so, where'd you get them? Also, has anyone gotten rid of the huge black license plate holder and rack? If so, what have you used to hang a license plate on the bike?
BTW, I assume turn signals are "required" here in Georgia?
Thanx, Lance
Old Feb 26, 2006 | 02:57 AM
sdunne's Avatar
Default RE: Turn signals/rear fender?
I got my LEDs from walmart but they are not working right because of the relay box Im going to try a heavy duty relay this week I'll let you know if it works.
Old Feb 26, 2006 | 03:00 AM
sdunne's Avatar
And you can order a new license plate holder made by acerbis check out baja designs web site and look in there catalog.
[IMG]local://upfiles/1071/1837216C4083456194B7AB0346A01563.jpg[/IMG]
Old Feb 26, 2006 | 07:05 AM
MaverickAus's Avatar
ORIGINAL: sdunne
sdunne, I bought LED's as well, you dont need a "heavy duty" flasher unit, you need one designed to work with LED's because of their low current draw. I can show you one in an Australian catalog, I don't know where you would get one in the states
http://www.narva.com.au/Switches_38.html (68249BL)
the 2 pin is suitable for the KLX however its not a direct swap and you need to change / modify the stock connector to fit the flasher unit. Also it won't just fit onto the bracket for the original flasher is so I will probably zip tie mine when I get it
Garry
p.s. in case you don't know the stock flasher unit is behind the headlight
joelcool64
Sep 28, 2011 02:09 PM
ben_cline
Ninja 250R
Sep 19, 2007 08:54 PM
95zx6rGuy
Jun 6, 2007 02:33 PM
LordVngr
Oct 30, 2006 06:30 PM
jsac
Sep 9, 2006 02:26 AM
