TPS or not to TPS?
1 Attachment(s)
So the new carb I got is from a 09 and mine is an 07. My 07 has a TPS installed and the 09 does have it. Would there be a problem not running it? Also the 07 does have the idle adjustment extension, just an inconvenience.
That was 5 years ago bud. That dude did the typical ask and never return.
Originally Posted by toomanytoys84
(Post 524451)
Originally Posted by Ruggybuggy
(Post 524452)
:confused:
Posted in the wrong thread from my phone. Sorry man! |
(Post 524453)
You'd need to know if the TPS dealt with timing. I think anyone who has gone to a TM36-68 would be able to tell us if this is an issue since the TM doesn't use a TPS either. Does it screw with timing if disconnected?
My real question is there are two virtually identical carbs laying there, why the change? Is the older body broken? If not, why not replace whatever needs replaced in the older body since there would be no gain otherwise? That's like swapping the same carbs, why bother. Wondering out loud. |
I went ahead and installed the 09 carb and left the TPS off. Seems to run fine, actually better than fine because the new carb came with a dynojet kit. I'm running DJ132, needle on 3 and a 40 pilot with the screw turned in. With the bike running I did connect the TPS sensor and turn it full open and closed and nothing noticeable. Maybe I'll put a timing light on it to verify.
and something is learned...
Someone here (raycour?) put an 06/07 ICU on a test bench once to see how the TPS interfaced but didnt see any result. Seems like kawi intended to do something with thier KTRIC system in the klx but may have decided to abandon it for whatever reason but the parts still made it into the final design without being implemented ?
Originally Posted by wildcard
(Post 524482)
