Torque specs question.
Old Feb 16, 2007 | 10:49 PM
Ginsu4u's Avatar
Default Torque specs question.
I'm going to look at the valves tomarrow and was wondering if someone could post the torque specs I may need. Planet KLX used to have a touque section in their tech-tips but its gone now. Any help would be appreciated. Thanks.
Old Feb 16, 2007 | 10:56 PM
Default RE: Torque specs question.
Valve clearance :
Intake: 0.10-0.19 mm
exhaust: 0.15-0.24mm
cylinder head cover bolts:
7.8Nm (0.8kg-m, 69 in/lbs)
if you adjust them, the camshaft cap bolt torque is : 12n-m (1.2kg-m, 8.5 in/lbs)
I think thats all you would need.
(just happen to have the service manual right here)
Old Feb 16, 2007 | 10:59 PM
Ginsu4u's Avatar
You're awsome EMS. Exactly what was looking for
Old Feb 16, 2007 | 11:04 PM
I know... i know... Your welcome
Old Feb 17, 2007 | 03:14 AM
A while back I copied down most of the commonly used torque values that I use and printed them out using a tiny font, then laminated it into a little card that I keep in my tool bag. All the torque values are in the service manuals, but they are a lot more handy on that little laminated card.
Old Feb 17, 2007 | 03:34 AM
tremor38's Avatar
ORIGINAL: EMS_0525
Valve clearance :
Yeah the shops over here round-up the cover bolt torque to 1kg, but warn against going anywhere above that. REAL easy pull the threads in that soft aluminum head.
Old Feb 17, 2007 | 01:42 PM
ORIGINAL: Nobrakes
So you carry a troque wrench in your tool bag too... ???
Old Feb 18, 2007 | 06:03 AM
Ginsu4u's Avatar
Sooo, my bike is in pieces in my friends shop. All the valves were at the tight endof the specs. I have the new shims that should put me right in the middle and will be installing them in the morning. I hope all goes well. Any advice would be appreciated.
Old Feb 18, 2007 | 06:07 AM
"Installation is the reverse of removal." - Kawasaki Service Manual
Old Feb 18, 2007 | 07:41 AM
Ginsu4u's Avatar
Yup, and keep an eye on that chain . I remembered your chain story as I had it in my hand. lol
