-   -   Torque specs (https://www.kawasakiforums.com/forum/klx-250s-71/torque-specs-22218/)
Tim1 Jun 11, 2008 02:28 AM
Torque specs
Does any one have the torque specs for the rear wheel nut & the rear sprocket screws?
I think there was a posting with all of the torque specs, but I can't seem to find it.
Tim1
Finger Mullet Jun 11, 2008 03:23 AM
RE: Torque specs
I used a torque wrench the first time I changed it, after that I just wrench it on tight but loose enough so I can get it off with my trail tire tools and don't forget the cotter pin.
Manual says 72 ft-lb rear axle nut
Front Axle nut 65 ft-lb
Front Clamp nuts 87 in-lb.....careful with these they are easy to breakoff.
Finger Mullet Jun 11, 2008 03:25 AM
RE: Torque specs
Opps didn't see rear sprocket nuts... 22 ft-lb
MaverickAus Jun 12, 2008 06:10 AM
RE: Torque specs
yes thats 87 INCH / pounds for the front, they are very easy to break. I replaced my broken ones with exhaust studs, they work just fine
