TM36 pumper duration
new TM36 installed and bike is running good now. Only question I have, what interval should I set the pumper actuator up for? I've seen from instant to 1/8th throttle and have no idea for how long the duration should be.
331 with open airbox, HMF exhaust. |
Mikuni recommends 1/8th to 3/4. If you look at IDRIDR's post on his 36 cable issue, he linked to my original post on my 36 where I describe how I determined the starting point of 1/8th throttle to the stopping point of 3/4 throttle.
thats what I set it at, so I'm good. Just need this snow to disappear so I can ride it.
I set the duration for best throttle response. The two that I've done came with too much gas being squirted.
Ride on Brewster |
Originally Posted by Brewster
(Post 506585)
Ride on Brewster Will you explain if your settings are different than described in these threads? |
Originally Posted by IDRIDR
(Post 506588)
Ride on Brewster |
Thanks, Brewster.
(Post 506585)
Ride on Brewster |
Alright. Bcak from the gave. Took the bike for a ride and its definitely too rich somewhere. Seems to be a bit flat at full throttle, so I'd imagine that's the issue.
331, stock tm36-68 with 17.5 pilot being the only change. Hmf exhaust, no air box cover. I can't find a standard answer as to what base settings should be. I'm thinking from what I read, p4 nj with y1-60 needle in 3rd clip? |
At full throttle opening, you're on the main jet.
Ride on Brewster |
