TM33 front Spigot adaptor
2 Attachment(s)
I turned up another one that's like 1/8" longer and bigger diameter by the carb. Anyone want this one I made that I was using? There's nothing wrong with it. It works great. I had to grind away part of the engine mount bracket for the carb to fit. I'll throw in the right size O-ring. I'll swap for a used rear sprocket 44-45 teeth. I just want to try that out to see if it'll work for my riding style. Or if you got anything else to swap of little value I could use. If you're real nice, I might just give you the damn thing. :p
Attachment 15809 Attachment 15810 |
